SXR 800 Prop Pitch Suggestions
Results 1 to 8 of 8
    Apr 2009
    Boston
    I'm in the process of tearing the motor down, boring and freshening things up. I was planning on having Impros clean up my current Skat 9/17 Prop or possible repitch. Note this Prop was repitched to 9/17 and I don't recall what it was originally. My tach at full throttle reads 7200rpm and my experience with stock pipe SXR's is that there really not much more top end to gain past 3/4 throttle. My boat has good bottom end, but wouldn't mind trying to squeak a little more out of the top. Anyone have a similar setup? Is the 9/17 my best bet? Should I go back to the stock nozzle?
    Please help...it's getting warm outside
    Current Mods: (stock exhaust)-TBM 29.5cc limited domes w/ .060" aluminum base gasket
    -Wiseco 82.96 race pistons w/ boost port, true 800cc
    -TBM angled reed spacers
    -VForce V4 Reeds
    -exhaust stinger
    -temp bypass
    -12 vane magnum setback pump w/ 80mm nozzle
    -carburetor re-jetting
    -flame arrestors w/ water protector covers
    -port matched intake and exhaust
    -TBM ride plate, Works intake, pump stuffer
    Chicago / Portage, MI
    Re: SXR 800 Prop Pitch Suggestions
    Given that you're using a stock exhaust, that pitch doesn't sound too far off.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Top Dog
    Oct 2006
    under a ton of work
    10/18 works well on stock boats but seems you're running a skat set back so loads motor more but you might get away with it with the mods you have.
    Apr 2009
    Boston
    What about a 13/21 Solas? What do you think the performance difference would be between the Solas 13/21 and the Skat 9/17? I don't want to lose to much bottom end, but would like a little more up top.
    What speeds you seeing at 7200? I played with nozzle sizes on my 750 Sxi FP Limited pipe. 80mm got to peak rpm quicker but the 76mm made more mph.
    Stock pump
    Skat C-75 9/17
    53.5mph at 7400
    Top Dog
    Oct 2006
    under a ton of work
    13/21 is too much prop for your mods.unless you bore out nozzle and increase hp it'll kill the bottom and the top.
    Apr 2009
    Boston
    I have a 750 nozzle which I believe is 80mm. I don't what I'm getting for a top speed right now. Also, I should note I'm 6,3 240#. The 9/17 might be my best bet. I reached out to Impros via phone and email with no response. Not sure if it's a good idea to buy a new Prop from them or have them refinish my existing g one. Anyone know what's up with them?
    They respond better through email from my experience
