Kawasaki STX 1100 DI 2000 --BILGE
Results 1 to 2 of 2
    Oct 2017
    I have twin jet skis. While winterizing them I noticed one was leaking anti freeze inside the front of the jet skis.
    The other had no such issue. No antifreeze into bilge.
    Im asking is it normal for fluids to pour in the bilge or not,, which ski has a problem the one leaking or the one not leaking??? Many thanks for any help on this matter
    I dream skis GlenT's Avatar
    Jul 2002
    Surprise, AZ via NorCal
    Re: Kawasaki STX 1100 DI 2000 --BILGE
    No, it's not normal. Did you overfill it? Did you notice any excess water in the hull during the riding season? Leaking hose clamp? Stator cover o-ring? Engine gasket? Who knows. Get a flashlight and mirror and let the hunt begin. Should be easy to find. Antifreeze leaves a crusty residue when it sits for an extended period. Check the underside of the rubber coupler between the waterbox and exhaust. Sometimes they will burn through with age and leak.
    2004 Kawasaki SX-R
    2001 Kawasaki STX 1100 DI (GroupK Stage 1, STX-R rideplate, BH Sponsons)
