Is this hull repairable? - Page 2
Results 11 to 13 of 13
    Re: Is this hull repairable?
    Might as well put a 155mm pump in there. Half the work is done
    May 2013
    Norcal
    Have you tried launching at Mead without the DI? Not sure they really care...
    But to your original question unless you planned on replacing the pump mount anyway I would keep looking. That is a lot of work as pictured.
    Oct 2013
    Ohio
    When you said you can get the hull CHEAP, I would be thinking FREE, or walk away... If you really want to do it, find your donor ski and do some practice glass work. Then when you will know more what you are getting into. IF you still want to try it... then go back and ask the owner if he wants you to haul away his junk yet. It will still be there.
