Which Hull - 91 XP vs 94 SP
Results 1 to 8 of 8
    Oct 2016
    Washington D.C.
    Hey Folks,
    I have four hulls and three motors....
    Hulls:
    -91 XP
    -91 SP
    -94 SP
    -94 SP (parts ski)
    Motors:
    -587 white single carb
    -587 yellow twin carb
    -657x
    Which engine should I put in what ski? Is there any advantage to the later hull? The 91' hull seems to be about 15lbs lighter than the 94'. I bet the 91' hull would really rip with the 657x.
    The 94 hulls have sponsons, the 91 hulls don't. I was thinking I could swap the sponsons from a 94 hull to the the 91 xp along with the 657x motor and electronics...
    Thoughts?
    May 2017
    ny
    Re: Which Hull - 91 XP vs 94 SP
    The 94 hull is superior to the older so hulls it's older slightly different than the newer x4 hull and yea the 657x motor is one of those I'm on crack kind of engines pushing 80hp compared to a 580 which I think was like 55 hp you will be happy with it and you need to run all the electronics from a 657x ski to run that engine properly
    Aug 2008
    Boise
    I have a 90 and a 96 X4
    I put sponsons on the 90 hull with a ride plate extension. Those two mods made it ride much better. I think the G1 hull is way more fun then my X4 because it's lighter and more nimble. The only weakness is the handle bar neck. It's rather week.
    Your G3 hull would be similar to the X4, but it does not have the trim tabs, VTS, or a 720+ motor.
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
    Oct 2016
    Washington D.C.
    I think I'm going to go with the 91' XP hull adding sponsons and the ride plate extension.... Light and nimble is what I'm after... I likely won't be doing much riding in oceans, lakes or bays. I plan to ride this on the upper Potomac river here in MD. When the water is good and high there are tons of awesome rapids and cut-throughs with many skinny and wide parts of the river. Wouldn't mind a 50mph top speed... Is it doable with the 657x & 91 hull? I love the retro look of the 91' XP when compared to the later models...
    Aug 2008
    Boise
    Quote Originally Posted by NoRdO View Post
    Wouldn't mind a 50mph top speed... Is it doable with the 657x & 91 hull? ..
    I don't think that's enough HP. Upper 40s is about right.
    Just remember, that G1 hull is a lot thinner.
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
    Oct 2016
    Washington D.C.
    When you say thinner, do you mean the thickness of the fiberglass?
    Motor is also bored .040 over which I would hope might add 1hp. It will be a fresh motor when I'm done rebuilding it... I will be rebuilding the pump as well.
    I Performed a thorough maintenance on a couple of 657x powered SPX machines a few years ago. They were both bone stock and would just tap 50mph GPS on smooth water. I think with some port cleanup, and pump tweaking the 91sp will do a solid 50.
    Aug 2008
    Boise
    yes.. go look. the G3 hull is a little more stout. I have stress cracks by my seat and put in more glass to help out. Also, like I said, the strength around the handlebar was beefed up in the next gen hull (G3). If you ain't worried about hitting rocks, getting thrown around and needing to hang on the the bars, or you're 150 lbs.. you should be fine.
    tiny bit of info
    G1= SP, SPi, XP, SPX 88-93
    G2= 93-95 GT(s)
    G3= SP, SPX, SP 93-97
    X4= XP, SPX, SP 95-99
    http://www.seadoosource.com/seadoomodelreference.html
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
