Yamaha Wave Raider 1100 (getting 2 cylinder motor)
    Jun 2010
    PA
    I have the opportunity to pick up a raider 1100 with bad motor still in it for relatively cheap. Having no knowledge or interest in rebuilding the 1100 3 cylinder motor (i'd rather part what i can) is it possible to drop in a complete 61x motor and exhaust (from a trashed vxr pro hull) with little or no effort? Keep in mind that the 1100 has 6 motor mount points installed from factory, the only potential issue i can see is having to switch out the pto/coupler/midshaft................
    thanks for help on this and yes i did use the search function without any success......
    Jun 2010
    PA
    Re: Yamaha Wave Raider 1100 (getting 2 cylinder motor)
    Idaho/California
    I have your mid shaft , complete out of WR 700 we scraped , motor sits to the front4 mounts on twin , have all that stuff , should be able to use carb cables in the ski , electrical hook up on VXR box might be a little different but not too tough , that 700 raider is a 62t engine not a 61x but it will still go , I've seen 6m6 650s in these skis , sell em cheap , keep the good stuff , once you change mid shaft will have same coupler as your 61x
    Jun 2010
    PA
    BR - you confused me a little with that you wrote above.....
    If i'm understanding your reply correctly, the only thing i'll need is a new/difference mid shaft?
    Jun 2010
    PA
    also that raider 701 in the above picture is a 61x.....
    Idaho/California
    That mid shaft for sure , motor mounts are the same on the raider and VXR by part number , the 701 e box and mounts for sure , throttle cable and choke cable should work also from 1100 , all mikuni hook ups , fuel lines will hook up , just electrical hook up from ski to e box might be different from 1100 to 701 , not stop start but gauge and sensor plug in , but way easier than swapin sea doo engines , also you WILL need a 62t raider exhaust system front to back to make install whitey , raider pipes have BIG over the top chambers , VXRs have a blaster / superjet pipe that goes to the front waterbox , raiders have rear waterbox
    PWCToday Regular SurfSN's Avatar
    Oregon
    Iíve got your raider 701 exhaust system if needed
