    Sep 2008
    The flakka capitol of Florida
    Carriers for shipping engines overseas
    Anyone know of a reasonable carrier? Fedex/ups is over 1k, usps has a 70lb limit. It's going to a navy base in Japan.
    Re: Carriers for shipping engines overseas
    What engine is it? Most twins only weigh around 70#. I shipped a twin to Australia once on fedex flat rate international. Used cans of spray foam to secure it in the box.
    You could also stop by the local recruiting office. Ill bet they can help you get it there reasonably.
    Sep 2008
    Its an 1100 kawi, waywayn over 70lbs....
    Cypress, TX
    1100 Kawi weighs around 110 lbs+ depending on short vs. long block
