650 factory pipe in 550/750 conversion fitment?
Results 1 to 10 of 11
    PWCToday Regular jlunde's Avatar
    May 2017
    vancouver canada
    Just curious if anyone has tried?
    I notice it really depends on what setup you are using. I'm hoping someone has tried?
    I have a spare FP mani and head pipe off my sxi...just don't have a 650 FP chamber.
    PWCToday Guru 123hi's Avatar
    Jul 2014
    NorCal
    Re: 650 factory pipe in 550/750 conversion fitment?
    charlotte,nc
    i dont think the sxi manifold will work in the 550 hull because of how the manifold clocks the headpipe mounting. the sxi manifold clocks the headpipe farther clockwise so the large sx/sxi chamber will clear the hull. if you had a 650 3 bolt manifold and your existing headpipe, a 650 chamber should work. depending on which 650 chamber you have might require massaging the chamber and possibly gas tank, but its definitely been done.
    im sure you can find a 650 chamber on this site or facebook for sale and try it out. worse case you have to get an exhaust manifold too. i found a stock 650 silver diverter manifold for i believe $50-60 shipped.
    Mar 2005
    Santa Barbara, Ca.
    Depends what you mean by "Fit""
    I don't want anything hitting by at least 1/8" so I needed a blister on the hull... Others have shoe-horned them in but they must be hitting the bondline pretty good.
    Just my experience ...
    SE MI
    Mine is "in" my hull but touches the hull and tank,
    Jul 2014
    NorCal
    I should clarify...mine “fits” as BLRider described. Although, it does fit better than the Westcoast 650 pipe I was previously running - mainly due to the lack of a rubber coupler on the chamber.
    Resident Guru sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    I have a 650 Factory Pipe in my js conversion hull with a 650 motor, it's a tight fit but it's in there. You'll need to make a small dent in the chamber to fit around one of the flywheel cover bolts but other than that you should be good.
    Note: make sure you stuff the chamber into the front of the hull prior to installing the motor. It won't go in if you mount the motor first. Lol, I found that out the hard way.
    '90 650sx, full mod with all the bells and whistles.
    '84 JS550/650 pump swap with Viper 9000 motor.
    '93 550sx with a 650sx motor and Rhass pump kit.
    '81 JS440, full mod 550 PP motor. '
    '93 300sx/750 SP BOB.
    Special thanks to Chris Newmiller, the guys at Prowatercraft Racing, Rhaas Products, and Mitchell at M&M Marine!
    Are you guys using the Rhaas adapter plate utilizing the 1" set back option? Thought that might give you an extra 1/4" or so in hull width.
    Oct 2011
    Midland, Tx.
    My ski had the 650 motor mounts glasses into the hull, and doesn't use an adapter plate, so I have no idea.
    SE MI
    Quote Originally Posted by 2strokesmoke View Post
    I am using the rhaas plate but the 140 pump kit with the x2 driveshaft still needs to use the front mounts.
