Prop question
Thread: Prop question
    I dream skis Evil's Avatar
    Jul 2009
    Cameron Park, California
    Prop question
    Recently picked up an fx1 and need to figure out what prop I should buy.
    It's a 760(701 with 84mm pistons), sbn46 carb, b pipe, girdled head, and 140mm pump conversion.
    I'm looking for bottom end pop and saw that impros hooker prop may be a good fit, not sure on pitch though?
    Any help would be appreciated, thanks!
    1985 JS550 - Just a hull now
    1994 Yamaha Fx-1
    1969 Seadoo 372 Bombardier
    2014 Hurricane CF C2
    May 2007
    Re: Prop question
    I think what helps the most for your setup is the pump stuffer. I could not believe the difference when I tool it off and ran without it. Had the same setup as you with a 9/17 skat big hub swirl and bored nozzle.
    The 140 is such a good pump for the fx1.
    Jul 2009
    Re: Prop question
    I contacted impros and got a 9/17 big hub hooker. Will probably get a pump stuffer down the road
    1994 Yamaha Fx-1
