SX 650 with big pin 750 fuel system
    Dec 2017
    Chicago
    Hi All,
    First off, I'm a newbie so bear with me
    So I bought a 650 with a 750 engine in pieces and am putting it together. My question is regarding the plumbing for the fuel system. I have looked at both the 650 and 750 service manuals, but am still confused. My confusion comes with the pulse line. It seems like I have an extra line. The dual keihin carbs have a line running to the block. I assume this is correct? But what I believe is the 650's fuel pump also has a pulse line. Do I just bypass the pump and hook up the lines from the fuel tank and choke to the carbs? I'll post pictures. Thanks for the help! 20180225_001755.jpg20180225_001800.jpg20180225_001709.jpg20180225_001701.jpg
    Shiocton, Wisconsin
    Re: SX 650 with big pin 750 fuel system
    You don't need the 650 fuel pump anymore. The 650 engine (87-90 650SX) uses an external fuel pump; your carbs on your 750 have a built in fuel pump. Completely remove the 650 pump. The rear carburetor on your 750 is the carburetor with the fuel pump. This carb gets the fuel output line from the selector switch hooked to it,
    and also the vacuum line from the case. The forward carburetor is fed fuel from the rear carburetor. The fuel return line (back to the tank) is hooked to the forward carburetor.
    I haven't worked on a 750 Kawasaki in years, but this is how they are set up
    if I remember correctly, I'm sure someone will chime in if this is
    wrong.
    Dec 2017
    Chicago
    I see. Thanks for the help!
    Mar 2016
    Central nj
    I'd like to make a suggestion here. That 650 fuel selector switch is very restrictive. If you were running that 750, I would completely bypass the selector. In my opinion you should run the line directly from the reserve in the fuel tank straight to the inlet on the carburetors. I have seen several 750's, and even high, reving 650's lock up due to lack of fuel in a 650sx or x2 hull.
    Dec 2017
    Chicago
    Didn't think about that! One less thing to worry about/ break.
    Thanks!
    Chicago / Portage, MI
    Another rider from the city! I had a 650sx/750 and still regret selling that ski. I created a build thread, you can find it if you search by my name in the individual builds section.
    I kept the fuel selector but Keihin42 brings up a good point. I would ditch the stock fuel filters and go with a clunk arrangement. Those stock filters and plastic tubes can break easily.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Dec 2017
    Chicago
    I already ordered a clear 10 micron fuel filter! I was thinking about trying to keep the reserve with a larger, less restricting 3 way valve kept in the engine compartment.
