Results 1 to 1 of 1
    Sep 2005
    Charging Aluminum Flywheel Salvation!!!
    If you have a charging aluminum flywheel with a waster taper bore, this guy can salvage it for you. Alex at PFM Industries.
    I've had 2 reworked so far. Though the OEM hub adds a little weight over the aluminum only version, the weight is all inward close to the crank. I haven't run the engine yet but I expect unnoticeable change from the original.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust.
