Cylinder head studs install ?
    Jan 2018
    FL
    For the cylinder exchange program and reinstall of the cylinder cover studs, do you recommend locktite, anti-seize or nothing. Thank you
    PWCToday Regular SBT-Tech's Avatar
    Clearwater Florida
    Re: Cylinder head studs install ?
    Loctite 242 on each end of the studs.
    Jan 2018
    FL
    Thanks. One more question. Is it ready to bolt on to the base or does it need to be cleaned or prepped?
    Clearwater Florida
    Is what ready to bolt on? The cylinder head?
    Jan 2018
    FL
    Yes the cylinder head to the base. It was wrapped in plastic and looks ready to bolt on but I figured I would ask if I need to wash it down to remove any residues or if it's ready to go.
    Clearwater Florida
    Should be good to go, but I would wipe it off with some acetone or other solvent.
    Jan 2018
    FL
    Thanks much
