Yammie Guru's
Thread: Yammie Guru's
    Aug 2017
    alabama
    Yammie Guru's
    Well, I couldn't resist. Went and looked at the 97 1100, and the hull and seats are mint. It wont run, but for what I got it for its a good deal. Here's my question, figured the motor was toast, put a hot battery in it, and its seems to locked up. Looking over what I could in the dark, found where a oil line had come off, some oil in the bilge. Do you think it only locked up top half, or toasted the whole engine? Thanks in advance for any advice, before I tear into it.
    Re: Yammie Guru's
    It will depend on how long it was run after the oil line came off. You wont know until you tear it down how bad the damage is.
    Idaho/California
    Re: Yammie Guru's
    Just fixed a WR1100 , fuel pump quit , slowly , and overheated rear hole and windowed cases and almost threw rod , finally died , rebuild fuel pump when you build that engine , on this one all oil lines were connected , still changed the oil pump anyways and verified all lines pumping oil to air box , of course premix first tank of fuel also , keep fingers crossed it's just a seizure
    Re: Yammie Guru's
    Quote Originally Posted by KB2017 View Post
    Pull the pump out first it may be just the pump liner swelled up....
    Aug 2017
    alabama
    Re: Yammie Guru's
    engine is toast, rod broke, and beat the bejebees out of the inside of engine....
