Results 1 to 10 of 10
Thread: HX prop numbers
    PWCToday Newbie catpower's Avatar
    May 2008
    Iowa
    HX prop numbers
    I sold my HX and the buyer wants to change stock prop out with more low end to help him side mount. top speed can be sacrificed if need be. I thought the HX was slow on bottom end anyway. We have a 18/23 Skat but i'm pretty sure that is too tall and meant for speed. Can someone advice us on what size is good for desired results.
    Sep 2012
    Huntsville, AL
    Re: HX prop numbers
    You can call skat or solas and ask them. They should be able to help you out. I think I have a 16/21 which gave a little more bottom end on my stocker hx.
    Aug 2015
    Kalamazoo, Michigan
    Re: HX prop numbers
    I have a 16-21 that came off from my HX when it had the 720 motor in it. I would like to trade for a 16-23, 16-24 or a 17-22.20171109_065732.jpg20171109_065800.jpg20171109_070042.jpg
    May 2008
    Iowa
    Re: HX prop numbers
    ok ya so that 18/23 is tooooo much for a stock 720. anyone running a bigger motor that wants speed i'm sure this prop will be for sale.
    Re: HX prop numbers
    The 18/23 sounds like its for a modded 787. If he's a big guy like me he should try a 14/19 or 15/20. The stock impeller is 11/22 and they don't do well off the bottom.
    Re: HX prop numbers
    When talking impeller numbers remember, they will differ from manufacture. Hub design, blade design, blade overlap etc all make a difference in the way an impeller loads the pump, and engine.
    Even the same company, impellers will differ. A big hub swirl skat will be different than a standard straight blade scat.
    email watcon@watcon.com
    Please visit our web sites
    May 2008
    Iowa
    Re: HX prop numbers
    I spoke to Skat Trak and was told it is a swirl prop but is too much for a stock 720. This is a Skat Trak 18/23 swirl.
    Re: HX prop numbers
    Yeah that prop is way too big....& the 720 is a dog on the bottom & wont never pull very well off idle.
    Single carb helps the best & I just so happen to have a complete setup for that.
    May 2008
    Iowa
    Re: HX prop numbers
    just curious is that a single 44 or 46 with manifold?
    Re: HX prop numbers
    Stock Seadoo set up 40mm I body,I have everything you need except for the throttle cable which may or may not work....
    Intake manifold,rotary valve cover,40mm I body carb rejetted to elminate accel pump & rebuilt using Mikuni rebuild kit,flame arrestor housing pretty much a bolt on & go deal.
    I have done this swap before & it works very well for bottom end with no loss of topend. The single carb 720's are just a LOT more peppier than their dual carb models. This setup was used on GTI's,GS,GSI models.
    PM me if interested.
