Results 1 to 6 of 6
    Feb 2018
    cali
    87 js 550 exhaust gasket
    Guys, I am running the stock exhaust on my js 550, the large gasket I took out is solid with a pee hole at the top, the new one from SBT is open see picture, which one to use, the pee hole will keep the chamber surrounded with cooling water, the open gasget will let water run out the bottom with the exhaust, give me your cooling theory, also how do you size pictures, thanks.gasket.JPG
    Resident Guru Bionic racing's Avatar
    Idaho/California
    Re: 87 js 550 exhaust gasket
    The gasket between the headpipe and chamber in your picture is for a half pipe , is that what you are running ? If not it will flood your pipe and kill all power and speed
    Feb 2018
    cali
    I am running the stock chamber, the gasket on the left is the one included in the set SBT sells for all 80's 550's, I think what you are saying is that I need to put back in one like the one on the right so as to not flood the exhaust, correct?
    SE MI
    Yes, you are correct.
    Apr 2014
    MI
    So I thought theses are the oem style breadbox gaskets.. water jacket stops at the elbow.
    While the half pipes had the open (smaller) gasket.. water jacket continues to the half pipe/chamber.
    Apr 2014
    MI
    Have seen one post, suggesting the OP's solid gasket above was sold to dry a jetpower exhaust, rather than a half pipe. But i'm too new to 550's to know.
    http://www.pwctoday.com/showthread.php?t=215443&page=6
    Am curious, as people only seem to tap the brass plug at the end of the jetpower chamber to dry it out. This would seem a more measured approach, if that is what it was?
