Results 1 to 9 of 9
    Frequent Poster original420racing's Avatar
    Aug 2010
    FLORIDA
    717 ring gap question
    I have a wsm platinum kit.piston spec max is 18
    I have 22 to 23 is the going to be an issue.
    I don't think so but I thought I would ask.
    Re: 717 ring gap question
    That is a lot.....
    What is your piston to cylinder wall clearance? I am guessing you are out of spec.
    With that much ring end gap you will get a lot of blow by.
    email watcon@watcon.com
    Please visit our web sites
    Thinking the same as John.
    Aug 2010
    FLORIDA
    I will check piston to wall.
    I have read that race ski's they gap them up to 54 thousandths.
    Can the pistons be knurled. I just don't want to buy jugs it ran fine before .it ingested water 40 hours on a new engine.when I took apart everything looked new.
    Well, its not the end of the world. Could be the rings worn out too. We cant say for sure without some measurements.
    Aug 2010
    FLORIDA
    The piston is 6 thousandths at lowest and 8,000 at the highest point
    Aug 2010
    FLORIDA
    The piston is 6 thousandths at lowest and 8 thousandths at the highest point
    If you are saying that you have a maximum of 8 thou clearance, I wouldn't be scared to run it. I've run looser before with no issues.
    Aug 2010
    FLORIDA
    Yes thank you.
