Venture 1100
Thread: Venture 1100
    Aug 2017
    alabama
    Venture 1100
    Is a 1100 venture and a 700 identical except for engine? In other words, I've found a 97 1100 that is spotless, I've got a 96 700 that is dinged up. Can I strip everything out of the the 96 700, and it all fit in the 97 1100?
    Feb 2004
    Phoenix, AZ
    Re: Venture 1100
    the motor mounts are different and the 1100 has a bigger pump.. Why would you want to keep the 700, sell the 700 and keep the 1100
    1996 XP All the usual mods
    http://www.pwctoday.com/showthread.p...17#post4380117
    1996 WaveBlaster II 1200 conversion in progress
    http://www.pwctoday.com/showthread.php?t=477231
    Aug 2017
    alabama
    Re: Venture 1100
    the 1100 has a blown engine
    Aug 2017
    alabama
    Re: Venture 1100
    forgot to add that
    Thinks everythng sux =) Top Dog vomitspot's Avatar
    Mar 2005
    lost
    Re: Venture 1100
    the hull should have the motor mount location for the smaller motor
    nina hagen daz
    Re: Venture 1100
    You will also need an impeller from 98-up XL700. Otherwise it will strain and blow the engine.
    Aug 2017
    alabama
    Re: Venture 1100
    Was just planning on changing out the pump and nozzle also. In other words, completely gut the 1100 hull, and install the 700 components.
