Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
    Mar 2009
    Fort myers Fl
    Re: 2000 rx problems
    Is this the correct white pipe? I assumed they didnít have a flat spot at all.
    PWCToday Regular scensor's Avatar
    Jun 2013
    Greece
    Measure the exhaust side circle diameter and let me know. It looks like the white one. They all have flat spot. From what I can see it's the correct one, later black pipe says warning hot on it this one isn't that's a good sign,
    If diameter is 65mm you are good to go
    Mar 2009
    Fort myers Fl
    Iíll measure when I get it, itís on itís way.
    Also after inspecting the crank. It seems to be perfect. All bearings are in really good shape, everything feels tight and smooth. Do I need to replace it? Does everyone just replace them all the time? Seems like this would be expensive rebuilding this every hundred hours if so
    Mar 2009
    Fort myers Fl
    Recieved today. Looks good. So Iíll just take a porting burr to the inside of the manifold to open it to 65 and blend it in a bit.
    Mar 2009
    Fort myers Fl
    Also received R&d 46cc head
    Thanks matt
    AND.....
    1017 top end
    Thanks mentzel
    This thing is sure pretty.
    Jun 2013
    Greece
    Goodies all around well done!!
    Mar 2009
    Fort myers Fl
    Also have a R&d power plenum on the way. With these mods should I still be fine with the 2.0 needle and seat? Getting ready to order them. Should I bump it to 2.3? Any advice on where to start with the jetting?
    Jun 2013
    Greece
    2.3 90gr silver spring as for jettings I'll need to see what I had been using in a similar setup. I've been using novis 48s and buckshot 47s for over a year now. Mikunis are sitting as spare just in case
  9. #29
    Mar 2009
    Fort myers Fl
    I wish. Donít have another 600$ for this project lol. Maybe next year if I get it running pretty good Iíll upgrade
  10. #30
    Resident Guru SURFnTURF's Avatar
    Sep 2004
    AUSTRALIA
    2.0 N/S will flow more than enough fuel for this set up.As long as your pop off is below 21psi.
    I use 2.0 N/S and black spring with highs 167.5 closed,95 lows open 1.5 turns,87.5 if pumps are used
    I have had at least 4 failures from using those R&D heads, they seem to have hot spots in them I dont like them at all.
    The better and safer option is to machine your existing head down and use a gasket,after all how many times will you change domes ??
    You could have your PTO machined down to the diameter of the coupler, this works well and gives good low/mid range power
    Install a lightened or aluminum flywheel, this helps as well
    Use a stock prop machined out on the outer edges then an interference fit with the pump liner, revs should be 7140-7200 with a good prop and white pipe pitched correctly
    These white pipes will spin 7400 no problem if you re pitch to suit and the engine feels like a singer sewing machine................
