HELP. 1994 WRIII GP bogging issue ??!!
Results 1 to 10 of 11
    Feb 2017
    Mechanicsburg, PA
    Hey need some help. My 94 GP has a fresh 701 rebuild and carb rebuild. It fires up great on the water and goes like hell for 10-15 min. Seems like after 15 minutes or so if Iím stopped or idling when I go to take off again it bogs down and cuts out. IT will fire right up again but every time I give it gas it cuts out. Anyone ever have this issue before? The inline fuel filter was changed before I fired up the rebuilt motor. I deleted the oil injection during rebuild as well. Any help would be great! Thanks!!
    Re: HELP. 1994 WRIII GP bogging issue ??!!
    After it bogs, immediately go to shallow water, hop off and pop the hood. Look for any sign of exhaust fumes. The fiberglass waterbox on those commonly blows open.
    Feb 2017
    Mechanicsburg, PA
    I forgot to mention it has an aftermarket TDR water box on it....
    Feb 2017
    Mechanicsburg, PA
    Your thinking it is an air leak?
    I did have one of these a few years back that gave me a run for my money, the culprit turned out to be a bad waterbox, my suggestion is simple find a piece of pvc pipe that will span the area the waterbox is in, remove the waterbox install the pipe and go run it, yes it will be loud but you will know within a few minutes if that is your issue or not.
    The waterbox on this particular unit did not have an exhaust leak , there was evedince that it had been run hot and melted the inside of the box obstructing the exhaust flow and making the ski run richer and richer till it would no longer plane out.
    Feb 2017
    Mechanicsburg, PA
    Interesting! Thanks for the advice. I will try it out.
    Feb 2017
    Mechanicsburg, PA
    Is it possible the overheat sensor if messed up? Fuel pickups?
    May 2007
    See if you can blow through the fuel tank check valve and make sure the vent line isn't bent shut.
    Feb 2017
    Mechanicsburg, PA
    I will thank you
    Just open the electrical box and unplug the heat sensor to determine if that is an issue or not. I have run across several of those TDR boxes where the baffles have come loose, if you shake the waterbox and it rattles it is bad.
