Impeller Direction Pitch Down or Up for More Top Speed Based on Peak HP - Page 6
Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
  1. #51
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: Impeller Direction Pitch Down or Up for More Top Speed Based on Peak HP
    Quote Originally Posted by zpilot View Post
    Transition between 1/4-1/2 is more like a sudden surge in power not sure if it the mixture or the pipe. Guessing mixture.
    Porting, that is how these are. Can you post a pic of the exhaust that came with the motor, I would be interested to see it, for curiosity sake.
    -95 750SXI
    -90 TS650
    -91 300SX
  2. #52
    Resident Guru zpilot's Avatar
    Jun 2007
    Los Angeles
    1995 Kawasaki SC
    PJS Viper 9000 800cc
    PJS Exhaust Manifold
    Coffmans Full Exhaust
    Custom Jetinetics Flywheel/drilled ring gear
    12 Vein SS Magnum Pump
    10/18 Skat Track Swirl Impeller
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    Skat 9/17 Big Hub Swirl
    UMI Bars
  3. #53
    SE MI
    I had a pipe like this once but the center had been extended 2"
  4. #54
    Mar 2005
    Santa Barbara, Ca.
    That crazy Japanese 550-850 conversion had one as well
    I couldn't get min to fit anything...
  5. #55
    Jun 2007
    Los Angeles
    Yes, I remember that ski well. Very sweet.
    From memory, the manifold to head pipe opening diameter was small like a Kawi 440 but the expansion chamber was a bit larger than my Coffman's pipe.
    1995 Kawasaki SC
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    UMI Bars
  6. #56
    Chicago / Portage, MI
    Interesting, the head pipe looks to be a mirrored image of the EX2650 650/750 pipe.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
  7. #57
    Jun 2007
    Los Angeles
    It does, I think this one had a 2 bolt attachment.
    1995 Kawasaki SC
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    UMI Bars
  8. #58
    Ooops meant the divergent section of the pipe. PJS logo and mounting boss are just perfectly reversed. And yea then a 2 bolt head pipe. I wonder if that's just a normal 550 piece. Interesting. I wonder if the convergent section alters the power band? because the EX2650's peak power is like 67-6800 rpm.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
  9. #59
    Jun 2007
    Los Angeles
    Not sure which side is considered the Converging or Diverging section but I believe the first half of the pipe with the mounting boss is an actual EX2650 if that's what you're saying
    1995 Kawasaki SC
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    UMI Bars
  10. #60
    Yep that's what I meant. Divergent = section where pipe gets bigger. Convergent = section where pipe gets smaller.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
