Impeller Direction Pitch Down or Up for More Top Speed Based on Peak HP
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
    Resident Guru zpilot's Avatar
    Jun 2007
    Los Angeles
    Very confused at what pitch direction to go from my current setup to achieve more top speed.
    My motor peaks 90-100hp @ 7300 rpm and i'm currently maxing at 6500 rpm. I'm running a big hub 10/18 swirl with great bottom/mid performance.
    Should I go down to a 9/17 to raise the RPM to get closer to peak HP/Speed or will I will benefit on the top by going up to a 11/19? I'm assuming peak HP would be the ideal target but not sure.
    1995 Kawasaki SC
    PJS Viper 9000 800cc
    PJS Exhaust Manifold
    Coffmans Full Exhaust
    Custom Jetinetics Flywheel/drilled ring gear
    12 Vein SS Magnum Pump
    10/18 Skat Track Swirl Impeller
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    Skat 9/17 Big Hub Swirl
    UMI Bars
    Top Dog
    Oct 2006
    under a ton of work
    Re: Impeller Direction Pitch Down or Up for More Top Speed Based on Peak HP
    go down and try to get closer to peak hp rpm.
    you'll gain in acceleration while keeping or hopefully increase top speed.
    SE CT
    What ski? Z pilot
    R.I.P. Super Sic
    charlotte,nc
    i believe hes talking about a super chicken
    Jun 2007
    Los Angeles
    Thank you. Yes, the SC.
    I’ll try the 9/17 but now need to figure out if straight or swirl.
    1995 Kawasaki SC
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    UMI Bars
    I agree with the above. The goal with impeller pitch is to get close enough to the target rpm without bouncing on it. A bit less pitch should get you there.
    Jun 2007
    Los Angeles
    Appreciate the feedback. I've read you can achieve up to 400 rpm pitching down so that should be much better. I can then start to play with pump reduction nozzle sizes to get a bit more and see how it performs then. Might even consider a custom 8/16.
    1995 Kawasaki SC
    PJS Rip Turn
    DG Intake Grate
    1994 Kawasaki XIR
    Group K Head Mod
    PJS Exhaust
    UMI Bars
    Chicago / Portage, MI
    Another thing to be mindful of is where that Coffmans pipe is making peak power vs the pipe that came on the skis with that pjs viper engine. Most of those wet pipes will be producing peak power somewhere around 6700-6800. Bill will know. He said the PJS EX 2650 was right around there.
    When doing unique conversions like this, I always find it's best to get a few impellers and swap them out and see how they compare. Definitely going down is the right direction though in this case.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Riverside, CA
    6
    Bill will know.
    Sorry I am late! I finally answered the PM.
    BM
    What were your thoughts Bill?
    Also Z do you know your current GPS speed? If I recall correctly, my xir with a factory pipe and a 9/17 straight impeller did about 47-48mph GPS. The SC has more hull wetted area but similar weight. Engine and pipe combo produces lower peak power than what you're pulling, but it did allow the engine to rev out nicely.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
