Results 1 to 9 of 9
    Frequent Poster gazza2010au's Avatar
    Jun 2010
    Australia
    1999 GTX 951 Carb Model, Starter Q
    Hey guys what is the best way to remove the starter on a GTX 1999 951 model? i picked up the ski for AUD$150 and i was expecting it to be seized but its all good just has starter issues
    Re: 1999 GTX 951 Carb Model, Starter Q
    If you take the carbs off you can see the starter better.
    2 bolts at rear of starter,the get corroaded & will snap off if you are not careful. I remove the motor when they get like that so I can use heat to keep them from breaking.
    Only use OEM starter & starter bendix......I have good used of both & I ship to AU.
    Sep 2008
    The flakka capitol of Florida
    May as well do some maint while youre at it. New fuel lines, pump oil, check the fuel selector and carbs for gunk.
    Jun 2010
    Australia
    Thanks i got the old starter motor out it was rusted and seized, while removing the old starter the front bit of the starter with the O-ring snapped off in the flywheel cover
    how would u guys remove this without taking off the flywheel cover and knocking it out? trying to do the lease work possible
    You need to remove front cover now....... I would remove motor.
    Sep 2015
    Northern Michigan
    I would take it out and spend the time now rather than later.
    Yep, take the pipe out in 1 piece, unhook some some stuff, pull the engine.
    Sep 2008
    Message hyosung, he lives in Aus. If you ask nicely maybe he'll share his tricks with you.
    Jun 2010
    Australia
    I have an idea i will let u know if it works, plan is to slightly tap the hole screw in a bolt with a flat bar attached to the bolt than tap the bar with a hammer to pop the broken bit out
