Polaris SLH stalls under load
    Dec 2017
    Boynton Beach
    I have an 01 SLH, that idles and runs out of the water. However, when I put it in the water it runs fine until about 3000 rpms, but you go past it dies, I can get it up to full throttle by messing with the choke while feathering on the throttle. I have rebuilt the carbs and adjusted the jets, but the result is the same no matter how I turn them in or out, so I have them adjusted back to 1 7/8. Any advice would be greatly appreciated.
    Re: Polaris SLH stalls under load
    If it is running poor, and you can get it better by playing with the choke, it sounds as you have a fuel related issue.
    When you rebuilt the carb(s) what kits did you use? Where they genuine Kehin brand, or genuine Polaris. Or aftermarket, like Winderosa, WSM, etc? I ask as I personally have never had any luck with ANY aftermarket kits. Also, you may still have some internal blockage. Especially if this is a salt water ski, I have seen carbs get really custy, to the point they really cannot even be rebuilt.
    Do not over look other issues / areas. A lean condition can come from an air leak, blockage somewhere else in the fuel system (ie fuel select vavle) bad fuel pick ups, fuel lines, bad reeds, and so on.
    email watcon@watcon.com
    Please visit our web sites
    Dec 2017
    Boynton Beach
    John, Thanks for the reply. I did use an aftermarket rebuild. I will order a new one. Also there is no air movement in the vent line. Could this be the problem as well? Could a blocked check valve or vent cause the same issue?
    Yes, vent line / check valve is also important, and needs to be working properly.
    Take the valve off, and try to suck/blow through it. It should go one way. (Let air into tank, not out).
    I have Genuine Kehin kits, and new check valves in stock. www.watcon.com
    Another thought, when you rebuilt the carbs, did you replace the needle arm spring? Did you make sure to match it to the original spring. Sometimes kits come with the wrong spring. Do you still have the original / old parts, and spring?
    Dec 2017
    Boynton Beach
    Thanks again. The check valve is definitely bad. I will get on the site and place an order!
