Seadoo 947r question
Results 1 to 6 of 6
    PWCToday Regular scensor's Avatar
    Jun 2013
    Greece
    Good day guys,
    I have a 947R engine with new pistons in it.
    Here is my issue in the below mentioned picture you can see the sleeve is cracked all the way on. Though you cannot feel it by hand I can see it.
    Will there be any problem running like this or should I replace the sleeve?
    All opinions are welcome.
    Thank you in advance
    Jun 2013
    Columbus, oh
    Re: Seadoo 947r question
    Yes, you must replace it. That's going to catch a ring and destroy itself.
    Did you just have that bored and new pistons installed? The pistons look new, but I don't see any cross hatching on the cylinders indicating it was bored to match new pistons.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    '89 Wellcraft Eclipse 21.5'
    '97 Seadoo GTI
    '98 Seadoo XP Limited
    '00 Seadoo XP
    Jun 2013
    Greece
    ANKENEYOU clear your inbox please
    SE MI
    Running it like that will last probably 10 - 15 minutes then another rebuild at a minimum.
    There is also about zero port chamfering around those ports.
    Riverside, CA
    6
    After you replace the cylinder, will the engine seize again?
    Did you find out what caused it to fail?
    Bill M.
