Results 1 to 2 of 2
    Jan 2018
    FL
    1989 650sx cylinder cover and cylinder to lower bolts question
    I am about to start reassembling this motor and was looking for some replacement acorn nuts to swap some that are really chewed up. I was thinking that normal style(non-domed or acorn) nylock or nylon insert nuts would hold better under vibration. Any reason not to? Thanks much
    PWCToday Newbie Cek08's Avatar
    Jul 2014
    United States
    Re: 1989 650sx cylinder cover and cylinder to lower bolts question
    No reason I can think not too
    Watch the chinese Stainless Steel though, sometimes the nickel is a little low percentage and it will rust
    also technically nylocks arent supposed to be reused according to some manufactures but i and im sure many others have reused the same one for years with no problem
    Good Luck!!
