gtx carbs
Thread: gtx carbs
    Aug 2017
    alabama
    gtx carbs
    will the carbs from a 94 gtx fit a 93 gtx?
    SE MI
    Re: gtx carbs
    I believe the 94 GTX came with the 657x motor and the 93 had a 657. The carbs were both 38's but the 93 had standard sbn design and the 94 had the "i" series sbn's. They are not interchangeable without changing the manifold too.
    Aug 2017
    alabama
    Re: gtx carbs
    I found a chart that says that that some are sbn 38's. But that they are a different jet size. If they would bolt up, would they work? would the jets have to be changed? or just tune with those jets? im not a carb guy. sorry if these questions are sounding right
    Idaho/California
    Re: gtx carbs
    Top bolt mikunis or do they bolt down with nuts to manifold parallel with linkage to connect them together
    Aug 2017
    alabama
    Re: gtx carbs
    They bolt down with nuts
    Idaho/California
    Re: gtx carbs
    Early type , same as 587 twin carbs , SBN 38 s , parallel with linkage , need that early manifold , or get top bolt manifold and go with your inline carb set up
    Aug 2017
    alabama
    Re: gtx carbs
    I have the 93gtx, I'm trying to find out my options for possible replacements. I've opened mine up, and a couple of the screws are rusted pretty bad. I wanted to find possible replacements, in case I break or round out screws. Planning on rebuilding mine. But didn't know if I would have to replace with exact year carbs. or if others would work. That is the only year with that particular part#. I was was wondering what all year carbs would physically fit. I can get new jets for about $3, if other years would fit. Not sure I'm making total sense. Thanks
