supertrapp knowledge
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    PWCToday Regular jlunde's Avatar
    May 2017
    vancouver canada
    bought a ST yesterday. i tried todo research on them but didnt find much as to what i was looking for..maybe someone with more knowledgeable would know!
    im running a 550sx/750 conversion. heres a few questions i have...
    1. should i be able to take the inside "grate tube thing" out? i read that keeping it clean is part of owning one...but mines riveted in.
    2. it also came with one "disk" that is more bowl shaped than a dought type disk. can figure out how that goes because the middle tube is riveted in. should i even bother with this because of my setup (550/750)
    3. what are most guys doing for conversions that run supertrapp? ie disks?
    thanks guys!
    SE MI
    Re: supertrapp knowledge
    I was running 18 disks and a closed and cap, ran awesome and had a really nice tone
    May 2017
    vancouver canada
    i wonder if its poosible to buy these disks still? maybe ill try to contact supertrapp....
    May 2017
    vancouver canada
    Quote Originally Posted by jlunde View Post
    someone posted an instruction manual for the supertrapp a while ago i think...i believe it said it came with 12 disks originally?
    May 2017
    vancouver canada
    Quote Originally Posted by JHR View Post
    yep i have the instructions,,,but im still not understanding how the disks are installed in this.
    May 2017
    vancouver canada
    Top Dog
    Oct 2006
    under a ton of work
    what you have is the end cap only and someone put rivets in the button holes to hold baffle in.
    depending on usage conditions,you had to clean the disks very frequently so it's possible previous owner was running with no discs.
    drill the rivets out and find correct hardware and discs .the instructions are pretty clear.
    who knows.
