Making the switch from Yami to seadoo.
Results 1 to 6 of 6
    Frequent Poster jmcdowell's Avatar
    Jun 2010
    Missouri
    Picking up a 2017 Seadoo RXP-X next week. If I don't find a trailer soon I will have to buy one. I am looking at a used one right now but am not 100% sure if it will fit. It's double trailer so that it can house my new ski and my GP1300R RRE.
    The man selling it states that he has had a single 03 GTX on the trailer before no problem and those dimensions are as follows.
    03 GTX :
    Length (ft) 10.86
    Width (in) 48.1
    2017 RXP-X :
    Length (ft) 10.88
    Width (in) 48.3
    My concern is the hull depth on that trailer.
    Does anyone have any insight as to how I can reasonably know?
    Thanks in advance.
    This is kind of an emergency as I have to leave to get this thing tonight.
    Sep 2008
    The flakka capitol of Florida
    Re: Making the switch from Yami to seadoo.
    No clue, but if time is a factor buy some 4x4's and bolt them to the bunks. Or just use 4x4,s instead of the 2x2 on there
    PWCToday.com Is My Home Away From Home Spim's Avatar
    Feb 2009
    Florida
    those brackets should be movable to raise the bunks if necessary.
    typically you can raise the bunk height on the bottom bolt and rotate the bunks to new correct angle on the top bolt.
    The problem with normal is that it just keeps getting worse...
    I would rather sit than quit...
    ______________________________
    Advertise here, Low Monthly Rates !
    Jun 2013
    Columbus, oh
    The rxpx has a very deep hull. It barely fits on the single trailer I have it on now even after moving the bunks closer together than I would like. My trailer even has the U shaped frame and it's only got about 2 inches of room. No other ski I've owned has come close to hitting.
    Even on my triton double I have to move the bunks close together to keep it from off the frame.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    '89 Wellcraft Eclipse 21.5'
    '97 Seadoo GTI
    '98 Seadoo XP Limited
    '00 Seadoo XP
    Jun 2004
    DFW- Texas
    You will have to move the bunks in more and like stated above replace them with a 4x4 instead. The deep V will rub on your trailer without changing this.
    16 RXP-X 300
    JS 550 with 650 Conversion
    04 RXP - w/mods - SOLD
    99 GSX Limited #1- SOLD
    99 GSX Limited #2- SOLD
    96 XP- SOLD
    95 XP- SOLD
    94 750sx- w/mods- SOLD
    94 SN Superjet- w/mods- SOLD
    04 Speedster 200 -SOLD
    So, what did you end up doing?
