Conversion ski 951
Results 1 to 8 of 8
    Sep 2015
    Northern Michigan
    Conversion ski 951
    I am looking for guidance for using stock electronics, and hpw to simplify them. I am using a 1998 GSXL as donor ski. Looking to simplify the stock electronics, would like to keep the raves the way they are. I have heard of others doing the same thing just haven't found any threads with specifics. Currently building a test board to do a little trial and error. Want to eliminate everything except the temp sensor, raves, DESS, STOP/START and ignition. Should have test stand up and running by Saturday.
    Dec 2011
    Niceville, FL
    Re: Conversion ski 951
    Sounds like you are just leaving the gauges and speedo paddle wheel out unless you have a 97.5 "grey ghost" donor and then you will want to leave the solenoid off of the carbs.
    What hull are you putting it in?
    Sep 2015
    Northern Michigan
    Good morning Matt. Yes and don't want the tanks sensors, mode/set buttons can go, VTS stuff also. I am trying to use the stock pipe first(known performance) then when I switch to the coffman Xpl pipe I will hit you up. I swapped the Xpl pipe last night to check clearances you gain 1.5" of clearance. This is going in a Air Blair fixxy, Jeff is finishing it right now. I will be bringing it down to your town in May.
    Sep 2015
    Northern Michigan
    Well got the test rig set up and started unplugging things as I went and talk about anticlimactic. I have the rear box connected as normal with the lead from the MPEM ,stator connected and the TPS and temp and thats it. And it runs fine. Now I can pair down the harness by about 80%.
    Dec 2011
    Niceville, FL
    Nice. You can get the little silicone fillers for the holes in the MPEM plugs that don't have wires in them.
    Sep 2015
    Northern Michigan
    Matt, your fu is better than mine. Do they actually make a port seal for the MPEM. Looked but didn't find.
    No, you pop the amp connector apart and pull the wires out. Then fill the remaining holes with the little silicone plugs. Then install the connector onto the mpem.
    Sep 2015
    Northern Michigan
    OK cool.
