all hoses and lines
Results 1 to 2 of 2
    Sep 2006
    california
    all hoses and lines
    I have 2 97 doos and need to replace all hoses never been changed. can someone tell me what I have to or are kits? Thanks
    May 2009
    South Carolina
    Re: all hoses and lines
    No kits available that I know of. Things to replace would be gas lines and oil injection lines if they have never been done. I have been buying my gas line at Lowe's since they sell a real heavy duty line that is close to the factory "Tempo" lines. I do not like some of the fancy gas lines since they do not come close to meeting the USCG specifications and could cause trouble. Last thing you need is for you ski to blow up.
    Oil injection lines are yellow Tygon "fuel Line" from Mcmaster Carr but I do not remember the cat # or size. Not sure you need to replace the polyurethane cooling lines, rotary valve lube lines, feed line to the oil injection pump, or the hoses unless you see some real problems.
    Think Big!!
