95 Yamaha Wave Venture no spark
Results 1 to 10 of 10
    Jan 2018
    Albuquerque
    I have a 95 Yamaha Wave Venture 700 that was running one minute, then suddenly shut off. After checking alot of different thing, i found that it has no spark. I changed the coil.....still no spark. Replaced the cdi......still no spark. Disconnect kill switch.....still no spark. I checked all the grounds and they're all fine from what i can tell. What else can i check? This is getting very frustrating! Please help!
    Re: 95 Yamaha Wave Venture no spark
    Bad stator ???
    Jan 2018
    Albuquerque
    Where is it and is there a way to check it?
    Under the front flywheel....
    Jan 2018
    Albuquerque
    Ok. Is there a way to check it, or do i just replace it? Also, can i just pull the cover off the front or do i need to pull the motor out?
    Thinks everythng sux =) Top Dog vomitspot's Avatar
    lost
    test it w a ohm meter
    nina hagen daz
    Quote Originally Posted by Johnnynieto View Post
    I can do it in the hull but in do it everyday.......I dont know your mechanical ability or if you have the right tools.
    Jan 2018
    Albuquerque
    I will give it a try without pulling motor. Never done it but i will try!
    PWCToday Guru Steve C's Avatar
    Oct 2002
    Franksville, Wisconsin
    Also, No spark at either plug? I would check the plug caps as well. Stock caps? That little wire inside the cap breaks over time. You can check with ohm meter. I would have to grab my manual from the garage to refresh my memory what it should read. Maybe someone here has it off the top of their head. Steve C
    There are several threads on this very subject, read them then get back to us.
    http://www.pwctoday.com/showthread.php?t=412279
    http://www.pwctoday.com/showthread.php?t=40840
    I was 300SXing when 300SXing wasn't cool !
