seadoo gtx millennium edition 2000 951 help
Results 1 to 6 of 6
    Jun 2017
    U.K.
    Hi people I have a seadoo gtx millennium edition thatís 2000 951 mine has on board REGULATOR RECTIFIER I want to put in an external one and bypass the internal one how do I do this need help please
    Jun 2013
    Columbus, oh
    Re: seadoo gtx millennium edition 2000 951 help
    http://osdparts.com/index.php?main_p...d=10082&zenid=
    Assuming you have a carb ski
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    '89 Wellcraft Eclipse 21.5'
    '97 Seadoo GTI
    '98 Seadoo XP Limited
    '00 Seadoo XP
    Jun 2017
    U.K.
    Yes is carb
    Jun 2017
    U.K.
    Hi mate what I want to do is buy a REGULATOR RECTIFIER from eBay and fit it all myself but need to know how to connect it do you connect it to the stator from the stator to the REGULATOR RECTIFIER then to the battery
    Jun 2013
    Columbus, oh
    Sorry, not sure. I never took the time to investigate since the kit I posted above included the upgraded 4tec rectifier and was ready to install. By the time I looked up parts cost alone, it wasn't worth the effort to me. I would be careful with eBay rectifiers, I've tried a few on a 96 xp and they typically fail very quickly.
    Maybe someone else will chime in that has done the bypass themselves. Good luck.
    '97 Seadoo GTI
    '00 Seadoo XP
    Yes, not worth the effort or time to make a wiring harness and keep everything watertight. Just buy the one from osdparts and be done with it. Ive used them a few times. If you buy a cheap ebay rectifier youll be lucky if it lasts a season AND you wont be refunded. So by the time you buy the second one youll wish you would have listened to the guys on this forum.
