rxdi problems
Results 1 to 10 of 13
Thread: rxdi problems
    Jun 2016
    2116 john arthur way
    rxdi problems
    To start off with. I have a 03 rxdi. It got sunk in the ocean. Changed the battery and rectifier. Pulled the plugs. Blew all the water out. Had it running but was running like crap. Done a compression test and found to only be running 90 lbs at that point I pulled the heads. So here is where my 2 part question lies. Put a puller on the wrist pins. Cranked it down to the point to where i though i was right before the "Oh ****". And the pins wont budge. That and i cant turn the engine over by hand. ANy insight or direction would be greatly appreciated.
    Aug 2012
    whitby ont canada
    Re: rxdi problems
    Do yourself a favor and just pull the motor, and take it apart, will be better to deal with it on the bench than in the hull and you need to split the bottom end anyway
    Re: rxdi problems
    Def agree with that. Also with mid pipe mount removed the whole pipe will come out without jacking with the big stainless clamp.
    Jun 2016
    Re: rxdi problems
    Yea that was my next step. I guess since this is my first time I ever done this. I wasn't understanding if it spun before it went down. WHy don't the crank turn now. That and I have a lot of insecurity about going into the bottom and making sure everything is timed right. Once I try to bring it back to life.
    Jun 2016
    Re: rxdi problems
    Oh i have probably torn down way more than i should. But I have pics. So I hope it goes well
    Aug 2012
    whitby ont canada
    Re: rxdi problems
    Down load the manual, read the engine section , take your time , keep it clean, and you will be fine
    Jun 2016
    Re: rxdi problems
    I have broken the engine down. I need a new oil pump. Where do I get the oetiker clamps that goes on the 3 lines from the oil pump and what size are they
    PWCToday Newbie Marky_Marc's Avatar
    Feb 2015
    Perth
    Re: rxdi problems
    Quote Originally Posted by cableg1020 View Post
    Most people just use high quality cable/zip ties, they work fine. Replace the oil lines as they are known to go bad. If not, your newly built engine may just go boom. Tycon fuel lines are a great replacement for the oil lines and are widely used.
    PA
    Re: rxdi problems
    Try McMaster-Carr.
    Jun 2016
    Re: rxdi problems
    ok It has been rebuilt and i am down to three problems. 1] The maint. is flashing along with the red light 2] I have water coming into the hull. It looks like from back by the exhaust as the two plastic pieces around the back exhaust where the water separator is. It has a separation in them. 3] the starter will kick the Bendix out but it doesn't hit everytime.. It is just a loud whine. Which it didn't do when the motor came out. And it looked tight when it went in. Please don't tell me i need to pull the motor again to get the Bendix out.. But i know you may
