Fiberglass & Resin
    Aug 2013
    Galena OH
    Fiberglass & Resin
    I recently got a 96 GSX project that I am now working on to have for this summer. After scrubbing out inside of hull I found several cracks fwd. of left rear engine mount. There is no apparent damage ( scuffing, scraping or gouging ) on underside just below the cracks inside. I plan on on sanding, cleaning & laying on a couple plies of fiberglass & woven matting. My question is, will store bought resin & hardener work (NAPA, Advance Auto Etc. ) or should I spring for the more expensive West System resin? This will be a Rec. ridden ski, stock 787 engine etc. Thanks in advance for any advice.
    Re: Fiberglass & Resin
    The Seadoo hull is built with Polyester resin so it will work, epoxy will of course be stronger and more expensive, for a small lob like that a small west system kit should be enough resin to do it . You may also consider looking at the G FLEX West system epoxy products, these have the added benefit of having some elasticity to them.
    Aug 2012
    whitby ont canada
    I really like the west system because you also get the #404 filler to thicken the mix and lay it upside down if you need to,
    You can't go wrong with West System, it is however quite expensive, for a small project I say go for it, for those of us who use large amounts of resin per year there are better options such as US composites resin.
