Backfire in mag piston
Results 1 to 10 of 10
    Resident Guru DamageInc's Avatar
    Apr 2014
    Pismo
    Just did a carb rebuild on my buddy's 97 Polaris slt 700. He said he was having trouble at 1/4-3/4 throttle. Put all new lines in, just before the carb work. Found some black particles behind the screen just underneath the needle and seat. Cleaned everything out good, rebuilt the carb pump as well.
    Fired right up, as it typically did before, but seemed better after 1/4 throttle. Then started having trouble staying running. Eventually died. Gave it a choke, fired up again. But I noticed flame, or ignition of some sort down the throat of the mag carb, beneath the butterfly.
    Any thoughts on cause and cure would be helpful.
    96 xp stocker w/ the works
    96 xp stocker
    96 xp project
    92 X2 650/750 conv build
    90 JS440/650sx conversion
    04 YfZ450
    05 GSXR 1000
    Re: Backfire in mag piston
    It shouldnt spit back into the intake. Check the reeds.
    Apr 2014
    Pismo
    Yeah, just read a few threads on it. Shoulda Google it first.
    I'll pull them tomorrow.
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
    Apr 2014
    Pismo
    Opened it up, melted piston, problem due to a lean cond.
    Top end build.
    Thanks for the help.
    need to find domes for this. Any ideas where? I've been looking on line for two days.
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
    Resident Guru 785 lugs's Avatar
    Feb 2005
    chicago il.
    I have domes what part # do you have
    are your last 3 #s 025
    Apr 2014
    Pismo
    I'll check after work.
    Where am I looking for those #'s...?on the inside of the domes?
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
    Feb 2005
    chicago il.
    on the top of the domes
    Apr 2014
    Pismo
    3022025
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
    Apr 2014
    Pismo
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
    Feb 2005
    chicago il.
    ok i'll look today I should have them
