primer on a gp1200r ?
    Sep 2013
    nc
    can i use the oil line ports to hook the primmer up to since they are at top of the carbs ?
    Re: primer on a gp1200r ?
    Yep
    Sep 2013
    nc
    thank you grumpy
    What I usually do on those is put an extra Tee in the accel pump line and run the primer into that but the oil line fittings will work as well.
