1996 Seadoo Xp 787
    Aug 2010
    Lehigh Valley PA
    1996 Seadoo Xp 787
    Hello! My vts is not working and the Vts module only clicks when you hit the up and down switch. I did replace the 7.5 amp fuse and still nothing. The motor works smooth when I put power to it and the worm gear is free and everything looks good. I did accidentally connect the small black ground to the positive terminal when I was putting the battery in but thankfully everything else is good. Ski starts and runs good. Beeper even works now!! Any ideas before I go and buy a new VTS module unit. I know they fail almost as much as the motors but I keep my skis garaged and clean. I know there are three connectors up front at the Grey electrical box but all the fuses look good.
    Mar 2005
    Michigan
    Re: 1996 Seadoo Xp 787
    You're lucky you didn't fry the cdi and the coil!
    1997 Seadoo SPX---limited mod
    1996 Seadoo GSX--Cruiser
    Aug 2010
    Lehigh Valley PA
    Yes true! Most likely because the battery was only half charged!! I think I am just going to run in next year and search ebay for a good deal on a complete vts set up or try and find a manual adjuster off an HX!
