choke and primer...best of both worlds
Results 1 to 9 of 9
    Aug 2017
    Vancouver Island, Canada
    So I like primers sometimes and chokes for other times. Made me think, why not both so I came up with this.
    Got a primer bulb on ebay for $1.50
    Had the other fitting in my parts stash
    drilled 2 holes into the stock flame arrestor (obviously with it removed) and glued them in air tight
    then just connected it all up as seen in the pics.
    Now I have a choke for most of the time and for those cold mornings after a long time not running I can use the primer to help save my starter.......
    works a lot better than I thought it would! Just thought I'd share in case anyone is looking for ideas
    Nov 2011
    CT
    Re: choke and primer...best of both worlds
    I drilled and tapped one carb, leaving stock choke in place on my ultra150. You only need to feed one cylinder to get it started, I never understood why people plum all 2/3 cylinders
    Aug 2017
    Quote Originally Posted by turboman412 View Post
    I was thinking of doin that but my thinking is that if I only squirt gas/oil in one cylinder then the other cylinder is running without lubrication for a little bit.....Probably not a huge deal depending on if there's gas in your fuel lines
    Aug 2010
    Australia
    i just drilled a 1/8 hole in the air box and used a sauce bottle with 50/50 oil/fuel to prime all my skis !, high tech shyt right there
    modded X2 650
    900 powered custom 650 sx .
    Apr 2006
    Oregon
    Any particular brand of "sauce bottle" or will any old sauce bottle work?
    Home of Newmiller Machine
    Aug 2017
    Quote Originally Posted by hyosung View Post
    hahaha, just when I thought my $1.50 primer was the cheapest solution out there! whatever works eh
    Nov 2011
    CT
    Quote Originally Posted by Yabadabadoo View Post
    The cylinders are already lubricated, also run 1 oz per gallon in the fuel tank. If you look at using Tís to split the fuel lines to the cylinder only the one closest to primer gets fuel.
    Aug 2017
    Depends on the ski, 4 strokes are lubricated but not 2 strokes with oil injection block off like mine. I use a T and it seems to give both cylinders fuel just fine...
    Aug 2010
    Australia
    any of the squirt type ones will do the trick ,
    modded X2 650
