Skat Trak Damaged Impeller Threads
    Jun 2016
    Michigan
    The guy said "it cavitates." The shaft threads are welded to the prop threads. Can this be repaired or is it a paper weight? 💁*♀️
    Top Dog TMali's Avatar
    Mar 2011
    Brooklyn Center, MN
    Re: Skat Trak Damaged Impeller Threads
    Would cost more to fix than its worth
    Paperweight
    Top Dog
    Oct 2006
    under a ton of work
    a good quality tap should be able to clean the pump hub threads if not too boogered up
    Jan 2007
    Earth (but just visiting)
    That impeller is no good anyway.
