TBM on SXR 800 Anyone?
Results 1 to 10 of 10
    Jan 2018
    MI
    I am planning to order/install TBM carve plate (the one with four triangle holes), along with TBM Scoop grate, and Blowsion pump shoes. All testimonials welcome.
    I dream skis bird's Avatar
    Jul 2012
    La Crosse right on the RIVER
    Re: TBM on SXR 800 Anyone?
    I'll sell you my TBM Signature Series Ride plate with the cut-outs for $175 shipped. I never liked how it made my SXR handle. It'd be great for racing, but for rec riding it adds way too much nose pressure. It auto-tracks which is great for racing where you're always in somebody's jet wash.
    The Pump Shoe fill is the best handling mod you can do for your SXR. Once you fill those voids you can rip corners with out the pump randomly coming unhooked. I could not believe the benefits it added. You don't need the Blowsion kit, just use marine grade silicone, epoxy with filler, etc.
    I still rock the stock intake grate, but like I said before, I rec ride. I've cracked my intake grate twice riding shallow rivers, replaced each for $10-$20 a piece.
    Third Coast Freeride - Midwest Wave Warriors
    Wooka Wooka Wookay. Let's Fing Rage!
    TBM Scoop on the SXR is our favorite.
    TBM Ride plate is good, but I prefer an extended Jet Dynamics on a stock ski. TBM on an 1100 conversion works very well.
    Pump shoe, or stuffers as stated above are also a must.
    I have all available here, if you need.
    www.watcon.com
    email watcon@watcon.com
    Please visit our web sites
    Jan 2018
    MI
    Thank you for replies... I had some trouble getting my question out there, so with the delay, my TBM plate, and scoop grate are already on the way. I will give them a try, if too much on the nose, I will put plate up for sale.
    Jul 2012
    Quote Originally Posted by sxrtharasher View Post
    If you have too much nose pressure, you could try Tubbies to bring the front out of the water. Good luck!
    Jan 2018
    MI
    Hi WatCon/John
    Can you send part# and Pic of long, and short Jet dynamic plates. Do you prefer the long, or short version? I have a Jet dynamics on my wave blaster and love it, so I may order one and have it ready if I don't care for the TBM Signature plate.
    Top Dog
    Oct 2006
    under a ton of work
    tbm plate is a fine plate.you can always shim it if you feel too much nose pressure or add front tubbies to counteract that.
    a plate that works extremely well is the shredmaster v plate.doesn't bury the nose in turns and telegraphs you when rear is about to slide out.very smooth transitions and rails corners as well as any other.
    Jan 2018
    MI
    Thank you,
    How do you shim a ride plate?
    Thank you,
    Shimming a plate will make more nose pressure. ( You do this by adding measured washers, or shims between plate and hull). I doubt you will need this with a TBM plate.
    Triangle relief holes cut into the upper sides of the plate will relieve nose pressure.
    Jan 2018
    MI
    Thank you to all that responded. TBM plate, and grate arrives Friday and I cant wait to try them.... Unfortunately all the water in my area is now covered with a cold crusty surface known as ice.... YUK! Oh well, gives time to ready the skis.
