1985 js550 extinguisher cap
Results 1 to 10 of 19
    PWCToday Newbie Dats73's Avatar
    Dec 2017
    Washington
    I just bought a 1985 js550. It's the red hull with some blue on it. Red/white/blue.
    My question is, it didn't come with the extinguisher cap and there are no screw-in threads in the tube. I have a 1977 js440 with the threads.
    What cap should I be looking for?
    Resident Guru sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Re: 1985 js550 extinguisher cap
    Should have 2 pins that lock on the cap. I may have one.
    '90 650sx, full mod with all the bells and whistles.
    '84 JS550/650 pump swap with Viper 9000 motor.
    '93 550sx with a 650sx motor and Rhass pump kit.
    '81 JS440, full mod 550 PP motor. '
    '93 300sx/750 SP BOB.
    Special thanks to Chris Newmiller, the guys at Prowatercraft Racing, Rhaas Products, and Mitchell at M&M Marine!
    Dec 2017
    Washington
    Thanks.
    I just ordered a cap online. What do the pins look like or do they come installed in the cap? I could probably make them but wouldn't the inside pin interfere with your foot on the deck?
    This is another one of my rebuilds. Got to do it right.
    Top Dog
    Oct 2006
    under a ton of work
    pins are in the hull. cap has the bayonet recesses for them
    Dec 2017
    Washington
    The fire extinguisher tube has no indentations to take any pins it's just smooth all the way through. There's a hole on each side of the tube on the outside on the hull. I believe a cross pin goes in to hold the cap on from the outside anyways I found the cap online I just need to figure out where I can get the Cross Pin or find out what it looks like.
    Dec 2017
    Washington
    Well just ordered this pin. Instead of a twist cap Kawasaki designed this quick pull cap.
    Feb 2016
    New Jersey
    I have an '85 and this is fire extinguisher cap. This cap falls off very easy so I secured it with silicone sealant. Unfortunately I can no longer use the storage compartment.
    Dec 2017
    Washington
    I was able to source a new cap, o-ring gasket and pin but not the handle so I made one out of aluminum. Fits snug.
    Dec 2017
    Yucca Valley, CA
    Do you have a pic of how this pin fits?
    Dec 2017
    Washington
    Look close at my photo. The pin is the plastic bar just behind the handle. It has an eye in the center of it to slide over the cap. He just grabbed the handle and squeeze with your fingers to flex the pin inward and then the cap will pull out.
    The stainless screws are there to hold foam on the back so the cap will float.
