787 Leak down fail
Results 1 to 8 of 8
    Aug 2015
    Kalamazoo, Michigan
    787 Leak down fail
    My rave valve bodies are causing a leak down failure on my 787. I cleaned both mating surfaces extremely well and put new gaskets but they still leak.
    Thinking of using some Threebond 1211 to help seal them. Yes/ No suggestions?
    Aug 2012
    whitby ont canada
    Re: 787 Leak down fail
    I would remove rave and look closely at the base for cracks, flat stone the cylinder surface and try again, the rave housing has a small raised edge so don't stone it, if that doesn't work , yes a small amount of threebond , but be carefull not to plug up small holes in housing or rave will not work
    Aug 2015
    Kalamazoo, Michigan
    I did use a flat hone stone on the cylinder mount area and used a soft wire wheel on the rave mount area. Maybe I'll get another set of gaskets and try again before using the 1211.
    You cannot pressure test with the rave valves on, in the Seadoo pressure test kit is has blockoff plates for the rave valves. The enclosed pic is not of the factory kit but one very similar.
    Aug 2015
    Kalamazoo, Michigan
    I did use the block off kit and all was good so I thought I would check with the rave valves too. The rave valve mating surface leaks so I assume that's no good.
    So is it okay for that area to leak with the rave valve mounted????
    I have never checked one with the rave valves attached so I can't really say, I can say that if it didn't leak there would not be a block off plate for it though.
    Aug 2012
    whitby ont canada
    I test with rave plates on and with valves in stalled, I have found diaphram leaks at very low pressure around the spring area ( repaired by tightening the springs) as well as pin holes in the diaphram itself
    Cypress, TX
    Rave valves will not hold more than 5 psi...
