Trailer build - suggestions welcome
    So I can't find a suitable trailer to tow my 650sx and blaster 2. The double stand-up trailer I wanted to use wasn't wide enough. Nor long enough for the blaster.
    And the single trailer the blaster is on, well we thought of building a second bunk above it that swings down. But I worry about the center of gravity being too high. Plus you know complexity.
    Anyway my father has recently finished building a trailer for the family ski boat (and refurbished a second it sat on while he built it)
    He managed to get an a frame and axles/suspension. So were now looking at building a trailer.
    Is there any ideas anyones seen that they have thought would be a great addition. Or things they wish they had.
    Scratch building a trailer may as well make it tailored to our needs and wants.
    Re: Trailer build - suggestions welcome
    A link of chain welded to the rails every 2ft down each side would be handy. Tie down anywhere you need to. Steel or aluminum walk board down the center instead of a 2x6 that's just waiting to snap in half. Sealed LED lights for sure. Of course a nice locking diamond plate box for the front.
    Aug 2014
    or a used double trailer , that may need lights or bunk brackets, wires. Got em as cheap as 150.00.
    '94 Kaw TS
    '93 Kaw TS
    02' Kaw STX-R
