Water World ??
Results 1 to 10 of 11
Thread: Water World ??
    Mar 2005
    Santa Barbara, Ca.
    Water World ??
    So how did they come up from under of the water in the show at Universal??
    Did they have air tanks or something for the engines to run??
    Been a long time ...
    Top Dog RacerX2's Avatar
    Feb 2010
    Far Away From You
    Re: Water World ??
    From theStudioTour.com: Mariner’s first entrance is on a jetski from under water – he starts at the top of a metal slide backstage and is released down the ramp on cue, around 8 feet under water, under the set wall and up to the surface just as air cannons produce a “water explosion”. The specially modified Jetskis used in the show are Kawasaki 550s, Kawasaki X2s and Kawasaki Supersports. They’ve been fitted with extra bilge pumps and have had the motors modified to cope with the heavy usage on WaterWorld. The numerous tires around the tank edges are to protect the sets (and jetskis and actors) from damage if targets are missed.
    See di46 drink......See di46 drive......Don't be a di46......
    Aug 2011
    Austin, Texas, USA
    Re: Water World ??
    Quote Originally Posted by RacerX2 View Post
    I thought I saw some round noses last year at the So Cal Universal.
    Riding mostly Lake Austin
    PWCToday Regular 1978js440's Avatar
    Oct 2008
    Goleta Calif
    Re: Water World ??
    Round nose yes! I found this on the theStudioTour.com site. Lots of info and pictures for the show, some with the water drained from the set. You can see the ramp leading to the underwater door.
    Jan 2007
    Earth (but just visiting)
    Re: Water World ??
    Round nose? Looks like an SXR 800
    Re: Water World ??
    Definitely an SXR.
    Top Dog orangefinger's Avatar
    May 2006
    Reno,NV
    Re: Water World ??
    thx for sharing the drain pictures...that's quite impressive
    94 Blaster "KAW 1100cc"
    650 SC
    Aug 2011
    Austin, Texas, USA
    Re: Water World ??
    Is this a round nose?
    Michigan
    Re: Water World ??
    Cool pics!
    Michigan
    Re: Water World ??
    Quote Originally Posted by linkman View Post
    Yes! That is a RN SJ!
