Anti Rattle jet pump cone kit
Results 1 to 10 of 12
    Feb 2017
    Brampton
    Hi everyone. just a quick question does anyone know if there is an anti rattle cone kit for the jet pumps on my 96 speedster.
    cant find any. the closest is this one from sbt but says it is for 1997 speedster
    https://www.shopsbt.com/jetski/sea-d...42-GS-GTI.html
    will this one fit and work with my 1996 speedster?
    thanks.
    PWCToday.com Is My Home Away From Home Maulin Marto's Avatar
    Sep 2009
    IL.
    Re: Anti Rattle jet pump cone kit
    Yes, It will work on the 96 pumps.
    2010 UWP Masters National Champion, Governor's Cup / 2013 GLWC Masters #1/2013 GLWC Ski Slalom #1/2013 Vet Open #2
    2009 & 2010 Vet Open Great lakes Champion /2009 GLWC Masters #1 2009 Sport spec #1 /GLWC 2011 #3 Vet Open
    Ebay Store Link> http://www.ebaystores.com/unclemartospartsstore
    Jun 2013
    Columbus, oh
    Your boat has the small hub 140mm pump so that kit will work. I'm personally not a fan of SBT though and their Chinese parts. You can get an OEM kit from osdparts.com for a few bucks more. If you email them and ask for a forum discount or add notes to your order you'll get 10% off.
    http://osdparts.com/index.php?main_p...oducts_id=8267
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    '89 Wellcraft Eclipse 21.5'
    '97 Seadoo GTI
    '98 Seadoo XP Limited
    '00 Seadoo XP
    Feb 2017
    Brampton
    thanks guys appreciate it.
    Feb 2017
    Brampton
    also would my pumps be RFI or None RFI. sorry just a little on the new guy side with this stuff.
    Jun 2013
    Columbus, oh
    You have the small hub non RFI.
    Seadoo later came out with Rotax Fuel Injected (RFI) skis which used a 140mm large hub pump. They offered better holeshot and were also standard on a few boats like my 98 speedster.
    '97 Seadoo GTI
    '00 Seadoo XP
    Feb 2017
    Brampton
    thank you again
    Feb 2002
    Vancouver, BC Canada
    Why do you need one? The anti-rattle cone will only fix the low-frequency knock while idling in the water. You usually can hear this knock when the idle is set too low. Make sure the idle is set at 1500 RPM, or a little higher, in the water. However, if you're experiencing an impeller rattle while running the boat on the trailer, this will not fix that. The impeller is rattling on the splines and it's normal.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Feb 2017
    Brampton
    Chester
    It is more for the thrust bearing than anything else I have had a few of the get pinched creating a lip on the inner hole of the thrust bearing from the forward and back movment
    Feb 2002
    You just have to be more careful when putting it together. It can still happen even with the anti-rattle cone during assembly.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
