Sxi pro mods on a budget - Page 2
Results 11 to 17 of 17
    Sep 2017
    Europe
    Re: Sxi pro mods on a budget
    Quote Originally Posted by Jim_ii View Post
    What do you mean by “grinding down the butterfly stops”?
    I haven’t seen any homemade hull extensions.
    I found a thread where a guy mentions that he removed the aluminium tab that is molded in the throat of the carb which is used to stop the choke butterfly at the fully closed position, and he says that he gained a lot more flow through the carb, sadly the thread end pretty much without any conclusion except that he had to go from a 75 to an 85 jet presumably because of the increased air flow...
    PWCToday Guru Jim_ii's Avatar
    Aug 2011
    Michigan
    Never heard of that.
    Sep 2017
    Europe
    then it's probably not worth trying
    Sep 2017
    Europe
    Also i'd like to know will I lose any performance if I remove the waterbox? Noise is not an issue where I ride...
    Top Dog
    Oct 2006
    under a ton of work
    keep the h20 box.removal won't bring you any gains.
    Sep 2017
    Europe
    Quote Originally Posted by restosud View Post
    Okay, thanks!
    Sep 2017
    Europe
    Does anyone have any experience with lightening the stock kawi flywheel?
