SUV 1200 65U electrical help needed
Results 1 to 10 of 14
    Sep 2013
    houston
    Went to winterize the ski. Started right up to fog carb while running. Pulled plugs to fog cylinders and went start to turn engine over... Nothing. No click, no turn over. After further investigation I somehow had moisture in my EBox (clueless as to how), like a lot. So I pulled ebox to dry and clean. The red powered wires had some corrosion so I cut and replaced connections via soldering new marine connectors. Dielectric greased all connections. Replaces solenoid while in there.
    Put battery back in. I still get nothing... No dash gauge activity, no clicks, no turn over. I'm pretty mechanically inclined, but I'm stumped w this electrical problem. Start switch checks out. But I'm obviously not getting power to gauges or anything else.
    Anyone have wiring diagram for 65u 1200 (suv, xl1200 or gp1200)? I need to trace down where my problem is and double check to ensure I didn't miswire anything. Searched the inter webs to no avail
    thanks in advance!
    Re: SUV 1200 65U electrical help needed
    Sep 2013
    houston
    Thank you. But I don't even have my gauges working so I can't test to see if it is in PADLoC
    Why arent the gauges working ??
    Sep 2013
    houston
    I assume due to not getting power to the correct places. Hoping I didnt mis-wire when i replaced some of the red connections. Thats why im really looking for a wiring diagram.
    May 2007
    Press mode button and enter AAAA, if the battery gos dead or you disconnect it you have to do this each time.
    Quote Originally Posted by driftmaster View Post
    hahahahaha
    Sep 2013
    houston
    Pressed Mode button and entered AAAA. Nothing. Dash doesn't turn on or show anything. Yes lanyard is in.
    He doesnt know what he is talking about anyway.
    Do this....open electric box & jump the the 2 big red wires on the starter solenoid...does it turn over ??
    May 2007
    Quote Originally Posted by lorenplante View Post
    Check the fuse holder, with a meter to be sure. I had the one on my personal 65u go bad. It read good when checking but when put back in or wiggled just right it would lose contact again.
