Dial Gauge Recommendation for setting Ignition Timing? - Page 2
Results 11 to 13 of 13
    SE CT
    Re: Dial Gauge Recommendation for setting Ignition Timing?
    Saw a nice central tool one for 40 on e bay now
    R.I.P. Super Sic
    I always just set them up with screws in the center of the slots then turn the stator plate slightly ccw. They come out running great.
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    I posted the same question over at the X-H2O.com and OCD said I was overthinking the timing issue and to just line up the mark on the stator with the triangular indicator on the 701cc case. I didn't even know that there was one. But looking through my photos, there it is!
    At this point, I have no idea why Yamaha has a special dial tool to use for "tune up." Especially when my oem Yamaha Service Manual doesn't even say how to use it...
    Easy Peasy. Merry Christmas ***s and Gals!
    Learning Slowly...
