Dial Gauge Recommendation for setting Ignition Timing?
Merry Christmas guys and gals!
Do any of you have a link or other recommendation for Dial Gauge for setting Ignition Timing with the spark plug hole adapters?
Re: Dial Gauge Recommendation for setting Ignition Timing?
What engine are you working on? The only adjustment is stator or possibly flywheel key.
Myself: Merry Christmas!
'94 701cc Yamaha Superjet 62N engine. I have the replacement stator to install, but I need to make sure that it is correctly timed when I install it don't I?
While I can see how a dial indicator can be used to find top dead center, I don't know how to achieve 15 degrees B(efore)TDC by using it.
It expresses itself in terms of mm, not degrees.
Additionally, I don't see how I can tell when the plug sparks if the flywheel is off.
I know this can't be magic, but I am having trouble finding info on it and although my oem Yamaha Superjet Service Manual describes the Dial Indicator for engine tuning under the Special Tools section, nowhere does the manual say how to use the dial indicator or how to time the engine.
If you have any good links for timing the Yamaha 94 701cc Superjet, will you please share them?
(I am going to have to run to the Post Office to pick up one of my wife's Christmas presents before they close, so I will check back when I return.)
Learning Slowly...
There is a mesurement in mm.mabey in the specs.
 R.I.P. Super Sic
There is a mathematical relationship (formula) between the rotation of the crankshaft and the vertical travel distance of the piston. Each one degree of rotation translates to a sum quantity of millimeters to travel. The key measurements that you need to know is the rod length and the crankshaft web offset. From there you can figure out how many millimeters of piston travel corresponds to 15 degrees of advance before top dead center. The number is probably around 1.5 mm but you need that exact number to two decimal places and a dial gauge that's that accurate. As well, make sure the piston is as square as possible in the cylinder by rocking past that distance and bringing it back to that distance.
1992 750SX Limited
1993 750SX Modified
1996 Wave Blaster Stock
2003 Super Jet Stock
2005 800SX-R Stock
2009 800SX-R Stock
Waxhead and for others who may be interested, here is the link for the Yamaha Special Tool Dial Gauge (and extension recommended) by Yamaha in my oem Service Manual:
https://www.yocracing.com/accessory_...product=709648
Learning Slowly...
If only some one knew what that measurement was
 Originally Posted by E350
sweet, a bit more than i wanted to pay but a cool unit
Yes how strange no spec.for static test.
 R.I.P. Super Sic
- You may not post replies
- You may not edit your posts
Forum Rules
