Oops.. 550 leakdown fail
Results 1 to 6 of 6
    Sep 2017
    Indiana
    So I went off half-****ed last fall and bought myself an 82 550 to tinker with over the winter. I tore it down, replaced the crank, new seals and gaskets, gave it a hone and new rings. As I was cleaning off the old gaskets, I noticed there's a small indentation on the bottom case where it mates with the cylinders. Long story short, after putting it back together it's leaking where the dent is. Is there anything I can do or is it a case for a new case?
    PWCToday Guru kyleadams's Avatar
    Oct 2014
    Lodi, CA
    Re: Oops.. 550 leakdown fail
    Negative ghost rider, case is toastered
    93' Kawasaki 550sx
    Top Dog
    Oct 2006
    under a ton of work
    post a pic.maybe a small resurfacing of case and thicker base gasket to make up for it or a bit of jb weld?
    charlotte,nc
    you can use some yamabond or 1211 along with the gasket that will seal it up. hondabond is the same thing. you can find it at a local motorcycle shop.
    Sep 2017
    Indiana
    Given the fact that I've spent more already than I had expected, I figure another little bit for a more solid case isn't a bad idea. I like the idea of not having a repair/adaptation that far down in my motor. I don't really want to go back in anytime soon.
    Appreciate the input!
    charlotte,nc
    I wouldnt consider yamabond a "repair" or band aid by any means. Its what you use for the case halves already. Ive even heard of people running no base gasket and just yamabond to raise compression and lower the port timing. If anything you can use it as extra insurance
