2002 GTX DI rebuild at 262hrs or keep going?
    PWCToday Newbie Syuhas85's Avatar
    Sandusky
    Just random up in the air question only because I have 260+ hrs now and I'm rebuilding the jet pump as we speak over this winter ( jet pump rebuild kit, Groupk modded Concord Impeller & Wear Ring).... 951 still runs smooth starts right up I was curious if I Should rebuild the topend over the winter or just let it go till she zonks out or at least starts to loose power and rebuild the hole thing...
    I have all winter and there's plenty of hours on this 951 motor but like I stated still starts up instantly and smooth.
    “You can only be as good as you dare to be bad”
    Feb 2002
    Vancouver, BC Canada
    Re: 2002 GTX DI rebuild at 262hrs or keep going?
    It's time for a complete teardown. Or you could just wait for it to come apart by itself.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Sandusky
    Chester
    Thanks Chester,
    That's what I was thinking too, just wanted another opinion. Ill probably wait till she zonks out then if I'm rebuilding the hole thing screw it lol...
    I have a couple different customers with di machines maintained by me. One has over 400 hours. My advice would be to oreder the in-tank fuel filters and the inline filter kit and change all those. Also check/replace all oil injector lines. Most of the Di and Rfi failures i've rebuilt were from loss of fuel pressure due to clogged up filters. Go ahead and have your fuel injectors sonic cleaned and tested also. Most any performance auto shop can do that for you.
    Sandusky
    Thanks alot for the advice found a site that does Sonic clean for 20 bucks, and will get the filters ordered!
    appreciate it!
